Hunting Idle when cold
Car: 55 chevy,2000 corvette
Engine: 1990TPI and LS1
Transmission: TH350 W/gear vendor and 6 speed man
Axle/Gears: 85 corvette 3.07 and 2000 vette3.07
I have 1500miles on this new engine mild cam, 2 1/2"exhaust no cat full headers,1991 TPI, al heads,730 ECM SD. My problem is that it hunts for a stady idle (700-1000 rpm) from start up until it reaches 190 degrees. After it gets to operating temp it runs smooth and idles at 590-600. Any help on what could be wrong please help. thank you Mike
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Hunting Idle when cold
Is it slightly rich when cold and proper air fuel when warm? Idle seems to stabilize for me when I lean out and add timing.
Does the chip pull timing when cold? I would think you would want abit more
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
IMO, many hunting idles are from vacuum leaks. You say yours stops at 190*. Could it be that idle stabilizes because a vacuum line somewhere in the engine compartment might have a small crack or slit at its connection point that is slightly open when cold (ambient), but closes when heated? Might be worth a vacuum test.
yes it is a little rich about 11-13 it starts out at 11 and slowly climbs until closed loop. I'm going to get a can of carb cleaner and look for a vacuum leak.thanks for your help Mike
