Which prom for my Mutt setup?
Old Jan 2, 2011 | 07:24 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Wanted some input. I have a 5.7(LO5) from a 94 suburban, on top is a tuned port setup. Im running 305 gear, (19lb injectors and 305 prom)> I have to say, this setup is great, and the car seems to be running great. Im running a t-5 as well. My current prom is for a 305 auto. Ive upgraded exhaust,(
headers back), ported my plenum, added a better than stock air intake and filter setup, other bolt ons, etc. Just wondering what would be a better prom to use, a 350 or a 305, or probably the best route, a custom one....
Old Jan 2, 2011 | 09:01 PM
Re: Which prom for my Mutt setup?
Is there much difference between the auto and manual proms, as faras timing, and fuel curves?
Old Jan 2, 2011 | 09:53 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I'd say get into prom burning and you'll be better off than both of the above.
and yesy I believe there are several differences between manual and auto bins. Timing, idle, throttle follower, DFCO and probably several others.
Old Jan 3, 2011 | 03:21 PM
AmorgetRS's Avatar
What ECM are you currently running?
When I did my 350 swap I took the 305 5-speed bin and just copied the fuel and spark tables over from a 350 bin. That did well enough for a basic tune.
This was with a '165 ECM with the 6E mask.
Old Jan 4, 2011 | 07:22 PM
I figure a custom tune would be best, Ill have to get into that. Thanks
85 Jimmy
Sep 30, 2015 07:56 AM
mcgarnicle
Sep 24, 2015 07:18 PM
lethaldomestics
Sep 21, 2015 01:18 PM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
