Weird "noise" in ALDL data
Old Feb 9, 2011 | 04:12 PM
thebruce's Avatar
I have developed some sort of weird electrical "noise" in my ALDL data. At random intervals I get a row of data that is way off-- BLM Cell of 160, temp of -40, that sort of thing. The car seems to run fine, and I can delete all those weird points in Excel and get a good log, but I wondered if anyone else has seen this.
I have used the cable off and on for a couple years with no issues. And I doubt the two are related, but the problem showed up right when I switched to TunerPro V5.
Relevant specs: '165 ECM datalogging with TunerPro V5. USB ALDL cable purchased from one of the usual online sources, though I don't remember which.
Any suggestions would be appreciated.
Old Feb 9, 2011 | 04:51 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: Weird "noise" in ALDL data
mine used to do that on occasion. My issue was with my computer's usb port being a bit loose. I'd wiggle it or use a "tighter" port and it went away.
Old Feb 9, 2011 | 06:27 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Could just be you need to increase the delay between send and receive.
See here:
http://forum.tunerpro.net/viewtopic.php?t=2215
Old Feb 10, 2011 | 06:42 PM
nick9004's Avatar
Car: 1981 GMC Jimmy
Engine: 350 TBI
Transmission: TH350 soon to be 700r4
I had the same issue. Turned out it was something in my harness. After chasing and chasing it I Replaced it with a Painless Harness. Well worth the money, however that was just what was causing mine.
Also if you want to test it first before spend a few dollars on a harness go to Pick n Pull and grab one. I installed it super fast, I laid it on top of the engine, all the hot wires straight to bat. all the grounds straight to bat. When I saw this even worked better then the harness I had installed I new that was my issue.
Good Luck!
Old Feb 11, 2011 | 01:30 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
you could also change(i think) 2 values in the ADX to account for the checksum at the end of the datastream. worked great for me, i removed my ~20mS delays entirely and have yet to recieve a single bad frame of data.
Old Feb 15, 2011 | 06:23 PM
thebruce's Avatar
Thanks for all the suggestions. Didn't have a chance to work on it over the weekend, but I'll check the connection, then go to work w/ TunerPro if that doesn't work.
Falcon50
Aug 22, 2020 03:26 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
greenyone
Sep 8, 2015 08:41 PM
