WB factory flash
Old Feb 26, 2011 | 04:14 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
WB factory flash
I have an Innovate LM-1 has anybody done a factory flash for the firmware ?
Old Feb 28, 2011 | 11:26 AM
Ronny's Avatar
Re: WB factory flash
Mine is a few years old. You are refering to the controller? I dont recall there being a port for that? What port does your have that mine does not?
Old Feb 28, 2011 | 06:53 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
I have had mine for six years now an never had a problem with it . I'am starting a new tune an wanted things to go smoothly . The LM-1 still had the original battery an was dead so i put a new one an while re-adjusting the setting's for tunerpro i figured i should up date the firmware WRONG never should have done that now i got the black screen from corrupt firmware . I took the back cover off to take a look see . In my own opinion i can't seem them flashing the chips in their that are solder'd which is every one . I see a switch in their with jumpers so i figure the jumper must go in a certain position so it will connect via the serial cable an you can flash it with the firmware . Basically that is what you are doing when you update the fimware . Pretty hush hush over at innovate on this topic they want you to upgrade to the LM-2 . I made a post over their four days now an not a reply from them even their tech support no answer , makes me wonder if they even care about customer support .
Old Mar 1, 2011 | 09:18 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you tried calling them?
Old Mar 1, 2011 | 09:44 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Shoot me an email offline if you want, I think they have like a $75-we-fix-whatever-is-wrong deal or something like that. I can forward your info to the right folks if you want, I know a guy over there.
Old Mar 1, 2011 | 09:45 AM
Ronny's Avatar
Sometimes they are slow to respond on emails. At times they respond quickly. Did you email them direct to support or post on forum? I would do both. When I called I spoke to Felipe and he was very helpfull. Klatin responds on Forum from Innovate.
Old Mar 1, 2011 | 07:06 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Felipe just e-mailed me an wants my info so he can sit up an RMA . He never mentioned a price but if it is indeed a $75 charge it would be worth it to get in on the exchange if it still applies . When i replied back i asked if the exchange program is still offer'd . I did e-mail them direct an made a post next was the phone call . Craig i will see how things pan out TKS guy's
Linson
Oct 24, 2025 02:00 PM
armybyrd
Sep 28, 2023 12:16 AM
RS Reaper
Oct 17, 2018 07:52 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
lewandom
Oct 1, 2015 08:15 AM
