tuning for peak hp with 95% humidity outside and raining?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
So this guy is telling me that it doesnt matter how much humidity is in the air and that he can still get the same hp and make it run just as good in the rain and humidity as he can on a nice sunny day, is this true?
Transmission: 5-speed/T-5
Re: tuning for peak hp with 95% humidity outside and raining?
In theory, the ECM should be able to compensate for such conditions.
ok cool good too know ty
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You can tune for the air fuel ratio that makes max power, but that max power will be only for those conditions that day. A car tuned in 80 deg heat for max power wont always make the same max power in 50 deg cold air. The air density is less so less power is being made. ECM can compensate fueling to hit a targeted air fuel value in a variety of conditions but doesnt translate into max capable power of the motor. Its just max power for the current weather conditions.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The feedbacks are capable of temp, baro, for some density corrections but I do not know how you could compensate for water content in the air using what is available for measurements.
Hmmm...
Hmmm...
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
We measure "water grains" to quantify the o2 displacement of humidity.
3.8TransAM
Oct 1, 2015 07:47 PM
