42# Bosch 3 injectors constant question in tune.
My 93 LT1 is using BOSCH III 42# injectors. My tune is stating the constant is 42#'s, but my flow chart shows 42.6 at 43.5psi( from the company that flowed them on a machine), which my fuel pressure is.
Will .6 make any difference. It is running rich, to my eyes at idle. No datalogs to show yet, but just cuirous if constant should be 42.6 since they flow 42.6 and not 42. These are GM injectors not Ford.
Re: 42# Bosch 3 injectors constant question in tune.
No
Maybe your injectors are to big for your build
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The .6 difference will be hard to see.
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
What is the Bosch part numbers for your injectors? It should be 0 280 155 xxx . I was not aware of any GM Bosch III injectors that flow 42# at only 3bar.
Dont have the part number, but I think its these, 42LF29. They are solid Green, thin and light.
I got them from here.
http://fuelinjectorconnection.com/sh...wCat&Submit=Go
I think those may be the same as the 99-2000 volvo injectors. I also stumbled across this set of table settings.
May be helpful.
May be helpful.
Your injector offsets (vs voltage) could be different than what the PCM is using. (the bosch injectors might open&close faster @42psi than factory injectors at factory pressure).
You shouldn't try to guesstimate by feel on injector offsets; call bosch if the datasheet you got doesn't have that information.
I know the VE tables etc need to be redone. Do you agree with that on a speed density car?
Yes. The injector constant in the tune doesn't need to be precise. As long as it's accurate (close), you should be able to get your BLMs where they need to be by adjusting the fuel tables. Once you get close to 128 across the board, you can tweak the Open Loop AFR stuff as necessary to get open loop idle fueling where you want it.
New2Chevy
Oct 4, 2015 11:27 PM
Firechicken86
Aug 12, 2015 10:07 PM
