What TPS voltage??
Car: 1987 Chevrolet Camaro SC
What TPS voltage??
Simple question here..
I know that the TPS sensor should have .54volts if you measure it on the throttle body.
I have adjusted the TPS to that. But when I datalog my ALDL port the voltage shows about .40 to about .44volts at the TunerPRO program.
So the question is: should I adjust the TPS so it get's 0.54volt at the datalog program or the sensor itself with a voltmeter??
Car: check
Engine: check
Transmission: check
Re: What TPS voltage??
They really should match better then what you are seeing.
RBob.
The ADX file is correct. I have burned my own chip so I am familiar with burning and datalogging.
I also double checked the grounds for the wiring harness and they have both to good ground ponts on each of the heads on the firewall side of the engine. I have adjusted the TPS to .54volts now and got a steady voltage of .54volts at the TPS and .46volts on the computer when datalogging.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
