Changed to 4" air tube and larger air filter - WOW!
Same configuration as my old 3", but now with 4" diameter and a filter with a larger flow area. All I have to say is WOW. No A-to-B comparison dyno numbers to support what I'm saying, but the ol' butt dyno shows a significant improvement above 3500 rpm. The entire upgrade (K&N filter, 4" aluminum tubing, silicone elbows etc) cost ~$100. Well worth the money!
Re: Changed to 4" air tube and larger air filter - WOW!
Ask and ye shall receive! This picture was taken before I got the final hose clamp for the assembly. The expert eye will notice there's a hose clamp missing...
Also, there's a bracket that you can't see that's supporting the filter from underneath. The filter came with a 1/4-20 stud built into it which made a very convenient mounting point for it.
Car: 91 Firebird
Engine: 6.0
well that isn't a thirdgen engine bay.....
That isn't picking up any hot air off the back of the radiator????
Looks good otherwise!
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
i tried on my 88 to make a 4 inch cold air intake with a 4 inch maf. Didn't pick up to much maybe 5 hp but was a nightmare to tune, so went back to a 3 inch. Surprised you picked up that much power, what did the dyno say the difference was?
BTW, where'd you get the 4" maf? I may need one soon as I'm planning to change over to an LT1 PCM
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The LT1 MAFs are 3.5". I have one, and it doesnt pose any restriction, at least up to 6k. If your running a cam with overlap, Ive found that the intake ducting can have a significant impact on the torque of the engine. I surmise that this is due to the mass of the air in the duct preventing reversion from the cylinders, so teh engine makes more torque as you loose less cylinder pressure when both valves are open. I used this with my old isky cam to restore torque at low engine speeds by basically messing around with the intake until I got the right length. With an open element on the TB, the engine basically had no low end torque. With a properly tuned intake, at WOT, it behaved just like a cam with no overlap.
Car: 88 Camaro SC
Engine: SFI'd 350
As for the LT1 MAF itself, its actually a plastic insert on teh older models that has the sensing elements mounted to metal strips that run across. The plastic section then mounts between two alum. venturis with a honeycomb screen and an airfoil that straightens and directs air over the sensing elements. You cant relocate these, at least not easily. If you want to make your own MAF, you need to get one of the probe or blade types that you can install into a section of pipe. These are available on the later model GMs.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:52 PM
