Add TH400 kickdown on 7747...
So I started out with a v6/manual tranny and the previous owner dropped in a TH400 without a physical kickdown switch, and when I dropped in the 305 I switched the ecm to a 7747, can't remember the BCC for the chip I put in with it but I'm pretty sure it was for a 305/TH400.
Anyways, the question is how would I add the wire/relay for the kickdown with the 7747 ecm? Either that or if the wiring harness included it anyways in manuals where/what color would the wire be?
Thanks for any help
Thanks for any help
Car: check
Engine: check
Transmission: check
Re: Add TH400 kickdown on 7747...
Thanks for any help
Thanks for any help
As for the parameters, shoot, I've listed it here, need to find it. It uses the TCC tables to control the kick down relay.
Here is a decent thread on it:
https://www.thirdgen.org/forums/diy-...47-8746-a.html
That should do it.
{edit: I need to read better. The TCC output, pin A7, is pulled low when the kickdown is active. So wire the coil relay as +12 V ignition to it, then the other coil wire to the ECM.
As for the relay, ah, I know where it is, go here:
http://www.dynamicefi.com/EBL_Drawings.php
Third sheet down, at the bottom shows the TH400 kick down wiring. {/edit}
RBob.
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
darwinprice
17
Oct 11, 2015 11:51 PM
