MAF voltage 3.20
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
MAF voltage 3.20
did a datalog at idle. The car has a a surging issue at idle and the 02 bounces back and fourth between 4.44mv and 830.mv. The WB02 shows it bouncing between rich and lean(14.0-17.7). The MAF voltage stays at 3.20 volts the entire 2 min datalog. Does this sound like a bad MAF sensor? It has been descreened and definned
Car: check
Engine: check
Transmission: check
Re: MAF voltage 3.20
RBob.
BumpaD82
Feb 26, 2016 02:57 PM
