Datalogging Question
Old Mar 28, 2011 | 04:38 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
I'm a bit curious. I'm using EBL/Flash. If I wanted to datalog also using another program such as datamaster could I do that?
Old Mar 31, 2011 | 08:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Datalogging Question
Yes, it will be 160 baud. Can also use WinALDL. Data stream is same as a '89 - '92 VIN E Camaro or Firebird. Note that this is via the ALDL, not the EBL comm link.
RBob.
Old Apr 14, 2011 | 10:59 PM
slrvette's Avatar
Car: Corvette
I did try this and it didn't work, datamaster. Says the PCM isn't supported. I can't find a file for a 89-92 camaro/firebird VIN E, I find others but not the VIN E. Anyone have a link to where I can find that and a good thread on how to set up datamaster?
thanks
Old Apr 19, 2011 | 12:44 PM
slrvette's Avatar
Car: Corvette
Just to update this again. Today I tried using tunerpro RT with the definition file A083- LO3 88-92 camaros/firebird. Couldn't get this one to work either. 10K resister jumpered on usb cable.
So far the only thing I could use other than EBLs datalog was WinALDL
Sorry I was wrong... I needed to select the correct COM port. It is working
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
