need help with adjusting AFR at WOT
Old Apr 27, 2011 | 09:51 PM
91Camaro_RS's Avatar
ok so i had my car dynoed and the guy said my AFR was way to rich so i began to look into the problem looked at the dyno sheet and did some datalogging. I then bought a wideband o2 sensor and guage and sure enough it runs perfect at everything except WOT. its at about 14.7 under normal load and cruising, but once i go WOT it goes down to 10.2, and i would like to get it up to 12.8
i have a 5.7 355, 700r4, TPI speed density, 7730 ecm, using aujp.bin and the 8D.xdf
i have been using tunerpro rt, can someone help me figure out which table to adjust on tuner pro to lean it out at WOT? and how much i should change the values.
your help is much appreciated!
thanks
Old Apr 28, 2011 | 08:53 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: need help with adjusting AFR at WOT
You need to adjust the (P.E. % change to fuel/air ratio Vs. RPM table) smaller numbers will add less fuel.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
