Code59, No speed indication in TunerPro
Subscribe
May 22, 2011 | 11:52 AM
Hello!
I´m new to code59 and I have a problem.
The MPH gauge in TunerPro is not showing any value when I´m logging (the speedometer in the car is working OK). I don´t know if this is an issue but it feels like the TCC is depending on the speed signal.
The car is a Pontiac firebird -91
/Johan
Reply 0
May 22, 2011 | 12:52 PM
Re: Code59, No speed indication in TunerPro
Do you have the correct VSS type selected in the flags/options?
Reply 0
May 23, 2011 | 01:56 AM
I found a flag called "Magnetic speed sensor". It is unchecked so I will try to check it.
Thanks!
Reply 0
May 23, 2011 | 06:39 AM
It is working now.
Thanks!!
/Johan
Reply 0
Subscribe
