'FIRST' intake 383 tuning help
Old Aug 29, 2011 | 07:44 AM
  #101
gbayfisher's Avatar
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Re: 'FIRST' intake 383 tuning help
Originally Posted by 88gunmetalgta
You have the WB run through your Autoprom? I would guess the error is in there somewhere.
I wired in the WB output to pin D8 on my ECM, and it just worked. I transferred all my bin data to the ARAPWB, and added the wideband o2 item to the ADX, and everything worked fine. There was a little bit of discrepancy between the gauge and Tunerpro, but nothing to worry about.
Yes, its through the autoprom, weird that it reads fine during data logging, just doesn't record properly. I wonder if the there is a mistake in my adx not allowing the aux channel to record properly, or perhaps you can't record from an aux channel?
I looked at my ECM, pin D8 is occupied, but D9 isn't. Can I use D9?
Old Aug 29, 2011 | 02:33 PM
  #102
88gunmetalgta's Avatar
I'm skeptical about pin D8 being occupied. Yours *should* be the exact same ECM as mine...
As Orr suggested, try exporting the data and viewing it in excel. That may tell you whether its not recording right, or just not playing back right.
Old Aug 29, 2011 | 02:44 PM
  #103
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I will try to open it in excel, see what that tells me.
If there is only one D8 , I am sure it is occupied, I looked and looked, it has a green wire going to it. I will take another look tonight. 'Just' incase!
Thx!
Old Aug 29, 2011 | 03:53 PM
  #104
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
according to the wiring diagram for the 86 maf stuff, D8 and D9 are NOT used so you shouldnt have a wire there. 87-89 should be similar
http://www.eecis.udel.edu/~davis/z28...165v8tpi-6.jpg
Old Aug 29, 2011 | 06:13 PM
  #105
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
i checked the ecm connector, and d8 is clear, not sure what the h33l I was looking at when I last looked.
I just need to go out and find a terminal now, and try it this way.
Old Aug 29, 2011 | 07:04 PM
  #106
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I have a terminal!
Its all wired up, and ready to go. I have an arapWB bin ready to go but it is now outdated by my newer bin. How do I copy everything from my working bin over to the arapwb bin?
Old Aug 29, 2011 | 07:26 PM
  #107
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
remember what you changed and manually input everything again
Old Aug 29, 2011 | 07:40 PM
  #108
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Lol, I wasn;t looking forward to doing it one by one again, but I just did
thx.
Old Aug 30, 2011 | 12:00 AM
  #109
thx.
and.......?
does it work?
Old Aug 30, 2011 | 08:29 AM
  #110
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
and.......?
does it work?
Not sue yet!
I bought the innovate MTX-L, so it needs to be configured. I should be finished later today.
Old Aug 30, 2011 | 03:43 PM
  #111
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Just getting into the adx file for the WB data logging through pin D8.
I am using these ADX settings from another adx file, I am not getting a reading on tunerpro however.
Does this look right?
Old Aug 30, 2011 | 08:01 PM
  #112
Try logging with the .adx provided with the ARAP-WB download.
The most important part of the datastream definition is the packet offset. If that's right, and you're running the ARAP-WB bin, and your wideband is putting out the right voltage range, you should get a number on your tunerpro dash, even if the equation and labels aren't entered right.
Old Aug 30, 2011 | 08:29 PM
  #113
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I just tried with a fresh arapwb bin and the adx file that it comes with, still stuck at 7.35 with no movement.
Wb is suppling up to 5v, so i know the voltage is there.
Everything seems to be in place, but no go.
Its obvious I made a mistake somewhere, just have to find it!
What are your packet settings?
Old Aug 30, 2011 | 09:36 PM
  #114
I'm not sure what mine looks like... I'm not near my computer, and I haven't looked at tuning stuff for a month now, its been all transmission stuff
Maybe you have the wrong output wire hooked up to the ECM? I know on mine, the color coding on the wires was really confusing, and I had to pay really close attention to which wire was which on the gauge and the controller. Seems like that fancy new wideband you got would be simpler than my old outdated LC-1 though
Old Aug 30, 2011 | 09:40 PM
  #115
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
i am not overly concenred about right now anyhow, I can still see it on my laptop during the run, and on the gauge it self, I know i am in a good spot with the AFR.
Did you not get your trans redone?
Old Aug 30, 2011 | 09:54 PM
  #116
Ahh, I thought you weren't getting the reading through the ECM, not just the issue with log playback... If its kinda the same deal you were getting with your LM-1, it would indicate a problem with Tunerpro itself. You might try reinstalling the software.
I just got my trans put back in on Friday. I have to trailer it to the trans shop tomorrow to get the warranty validated, and then it'll be back on the road. I'm gonna do all the PE tuning I can without a dyno, and then work on that mid-throttle acceleration lean spot/knock retard problem I've got.
Old Aug 30, 2011 | 10:33 PM
  #117
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
When I connect it through D8, i get no reading other than 7.35, I went back to autoprom route which allows me to see it, just not record. I posted the problem in the tunerpro forums, see if anyone picks up on it.
I hope the tranny works out for you! We all seem to be chasing the same mid throttle accel lean spots. I solve it by by-passing mid throttle, and just go WOT instead!!
Old Aug 30, 2011 | 11:30 PM
  #118
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if your careful you can watch wideband and rpm at the same time No need for logging.
Old Aug 30, 2011 | 11:34 PM
  #119
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Oh I know, that's pretty much what I have been doing. Its just that it would be nice to use the capabilities of the equipment.
I have also used my wife to video the screen while I drive! Problem is keeping her hand steady when i drop the hammer, lol.
Old Aug 31, 2011 | 12:34 PM
  #120
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"Problem is keeping her hand steady when i drop the hammer"
Hahahaha, I can see where that would be a problem.
Old Aug 31, 2011 | 04:47 PM
  #121
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Does anyone here know the best table/scalars to hit for some rpm hanging during cruising speed?
This usually happens as the engine gets warmer and warmer, i start seeing some higher than usual rpm that acts as a cruise control, and doesn't settle off until I am stopped, even at that point it hangs from time to time.
All mechanicals in TB are good, no sticking throttle blades, IAC is new.
I would like the responsiveness that I see when the engine is cooler. Should i be looking at the dfco scalars or the stall saver settings?
What indicators should i look for that might point me in the right direction?
Old Sep 5, 2011 | 06:20 PM
  #122
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Update:
I tried using an older wb.adx I had here.. Low and behold... the wideband through d8 of the ecm works now! I wish I knew exactly what caused the problem but i was changing a few things around at the same time ( I know) one change at a time!
I think the issue was in the dash, I had the setup correct all along but it just did not display properly.
thx for the help
Old Sep 15, 2011 | 09:52 PM
  #123
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Does anyone know where the location of the Throttle follower(s) are in $6e mask. The only T/F i see is the 'IAC steps added to TF in drive', so it looks like this value is added to another table, but where is the main TF table or constant?
I am trying to settle the speed of the engine during an off throttle coast.
Old Sep 15, 2011 | 11:14 PM
  #124
panhead201's Avatar
Car: 1989TA WS6
Engine: 305tbi being modified
Transmission: 4l60e
Axle/Gears: .73
I'm sorry,I don't know the answer.Thanks,panhead201
Old Sep 16, 2011 | 07:38 AM
  #125
RBob's Avatar
Car: check
Engine: check
Transmission: check
These guys:
Code:
        ; THROTTLE FOLLOWER GAINS
        ; TYPE $6E MY89 L98 ARAP
        ; (msec/6.25)
LC555   FCB  5      ;  31 msec BETWEEN STP'S IN PK/NEUT
LC556   FCB  4      ;  25 msec BETWEEN STP'S IN DRIVE
			;		arg = msec/6.25
LC557   FCB  7      ; 1326 usec ADD TO TIME BETWEEN FOLLOWER IN DRIVE
			;		arg = msec * (32/6.25)
LC558   FCB  8      ;  50 msec ADD TO TIME BETWEEN FOLLOWER IN OPEN LOOP
			;		arg = msec/6.25
LC559   FCB  192    ; 150 STEPS/%TPS, TPS FOLLOWER SLOPE GAIN
			;		arg = STEPS/%TPS * 1.28
LC55A   FCB  75     ;  75, MAX STEPS IN DRIVE
LC55B   FCB  255    ; 0.996,  PK/NEUT STEPS/DRIVE STEPS	TF MULT
                    ; 		   	arg = VAL * 256
RBob.
Old Sep 16, 2011 | 08:39 AM
  #126
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Originally Posted by RBob
These guys:
Code:
        ; (msec/6.25)
			;		arg = msec/6.25
			;		arg = msec/6.25
                    ; 		   	arg = VAL * 256
RBob.
Thx RBob,
I am not near my tunerpro until later this evening, but I don't think these are in any of the expanded adx files. Seems to me that these are important tables to have exposed for adjusting/tuning. I will take a closer look later today.
Thx
Old Sep 16, 2011 | 11:41 AM
  #127
Code:
        ; (msec/6.25)
LC555   FCB  5      ;  31 msec between IAC steps in Park/Nuetral
LC556   FCB  4      ;  25 msec between IAC steps in Drive
            ;        arg = msec/6.25
            ;        arg = msec/6.25
LC559   FCB  192    ; 150 STEPS/%TPS, Throttle Follower slope gain by TPS
LC55A   FCB  75     ;  75, MAX Throttle Follower STEPS IN DRIVE
LC55B   FCB  255    ; 0.996, Throttle Follower Gain Multiplier
                    ;                arg = VAL * 256
renamed according to the expanded XDF names
There's also DFCO, Decel Enlean, and Stall Saver Follower scalars in the one I have.
Old Sep 16, 2011 | 12:45 PM
  #128
panhead201's Avatar
Car: 1989TA WS6
Transmission: 4l60e
Axle/Gears: .73
It seems like its gotta be the signal from the throttle position sensor/Incorrectly programmed for the increased demand,bad potentiometer?panhead201
Old Sep 16, 2011 | 06:20 PM
  #129
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Thanks for the help everyone.
I added these parameters to my xdf, It seems to all be there now.
I hope I can make good use of it now!!
Old Sep 16, 2011 | 06:38 PM
  #130
RBob's Avatar
Car: check
Engine: check
Transmission: check
Odds are you will make good use of it. Tuning the throttle follower (TF) adds a lot of driveability.
Same with the TCC lockup (if used).
RBob.
Old Sep 16, 2011 | 06:48 PM
  #131
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
RBob.
No doubt it will help once I understand how all the IAC, DFCO, and T/F parameters work together.
Its going to take many small changes.
Old Nov 17, 2011 | 07:54 PM
  #132
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi , this is the spark table for your 383 right ? can i use this for my engine? ived got a 383 also...
Old Nov 17, 2011 | 07:55 PM
  #133
Old Nov 17, 2011 | 10:53 PM
  #134
Displacement doesnt have much at all to do with spark advance. Much more important are things like head material and design, compression ratio, and fuel type.
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Jake_92RS
Aug 11, 2015 10:39 AM
