730 ECM - V8 Memcal Compatibility List
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
Hey guys, I'm looking for a V8 Memcal that I can use in my '730 setup. While having a look around I was amazed at just how many memcal's look the same/similar. I thought it might be an idea to compile a list of ECM's & Applications that the V8 Memcal's can be found.
How about the 165 ECM's? Can the memcal be used from them? Does it have the correct Knock filtering?
List - to be updated!
ECM: 1227727
Application: Corvette 1990-1991
ECM: 1227727
Car: check
Engine: check
Transmission: check
Re: 730 ECM - V8 Memcal Compatibility List
ECM: 1227727
ECM: 1227727
The '7165 ECMs use an external knock filter, there isn't one on the MEMCAL.
RBob.
Transmission: 5-speed/T-5
There is a list of MEMCALs in the fileman section on the Moates site that lists MEMCALs by BCC, and lists applications and ECMs with it.
88SS6SPEED
Nov 11, 2015 07:05 AM
2012sergen11
Oct 13, 2015 07:38 PM
