Extended VE table
Old Jun 16, 2011 | 02:45 PM
dcvnZ's Avatar
Car: 1992 Z28
Engine: 388
Transmission: 4L70E
Extended VE table
Hi guys, I'm new to tuning the 7730 and am using the Moates stuff with Tunerpro. How do I open the extended Ve table so I can tune to 6400rpm? I haven't been tuning it myself as I'm much more adept at the FAST XFI software so a friend has been helping me. We just can't seem to get the extended range. Thanks in advance.
Old Jun 16, 2011 | 03:14 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Extended VE table
its just a matter of checking the box in Flags/Switches.
if your not using S_AUJP_V4, then i recommend checking it out. it has a number of enhancements that i believe you will find very useful.
if you do try V4, there are 2 zip files you need to get.
S_AUJP_V4_1026.zip and S_AUJP_V4 Inputs.zip
also be certain to read all the document files, other wise you will have problems.
Old Jun 23, 2011 | 07:00 PM
dcvnZ's Avatar
Car: 1992 Z28
Engine: 388
Transmission: 4L70E
Gotcha, thanks for the help!
Old Jun 25, 2011 | 07:07 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Denn you mentioned the files, but not where they can be found or accessed. How about a link? (and passwords if needed)
Old Jun 25, 2011 | 09:13 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I downloaded them from Moates website. You have to set up a login there to get at them in the files and downloads area.
Old Jun 26, 2011 | 10:57 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The standard $8D bin files do not have the extended range. That is a custom addition.
There is an RBob patch file floating around somewhere that can be used with any of the $8D bins to give you an extended table.
The S_AUJP V4 has an even larger table defined.
Files are on Moates site (use the default login provided on the pages) no need to signup or anything if you don't want to.
Under the Custom binaries for GM.
Be sure to make the corrections to the released files as explained in this thread.
https://www.thirdgen.org/forums/diy-...-released.html
Someday I'll get around to putting up a new version and new TP definitions. Until then the fixes are easy to edit so its not a big deal.
db057
Jan 10, 2020 08:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
1992Z28!
Nov 19, 2015 07:33 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
