cooling fan/fan 1 not working
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
id post in the cooling section but ive tested all my connections to my cooling fan and it all works, relay works, etc. ive looked thru all the param's(S-AUJP) and set everything i could see. i lowered my enable/disable temps for fan 1 as well. when i tested the fan circuit from pin E8 i didnt see any voltage. i tested at the relay and at the ecm. am i missing something? that was the only connection i didnt even cut throughout my harness swap. thanks in advance!
Transmission: 5-speed/T-5
Re: cooling fan/fan 1 not working
How do you have the relay wired?
The efan trigger to the relay from the ECM is a ground trigger.
Engine: LZ9????
Transmission: 2004R
Engine: LZ9????
Transmission: 2004R
