Dyno tomorrow AM, WOT AFR tuning?
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Hello,
I have my car running pretty good but the WOT is way rich on the wide band, 11:0. Just want to make sure I steer the tuner to the correct table to lean out WOT. Do I just have him increase the values in the "Power Enrichment vs. RPM"?? Thanks
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Re: Dyno tomorrow AM, WOT AFR tuning?
I have to ask. How did the dyno session turn out? Any numbers before and after?
Car: 89 Formula 350
Made 336 RWHP and 360 RWTQ, that was with 31* timing and the AFR at 11.5 at WOT. Any more timing or leaning it out it would ping. I was running 93 octane but its 11:1 compression. It wants higher octane if I lean it or add timing, so thats all im getting on pump gas. Kinda sucks being it made 467HP and 517 TQ at the flywheel.
Engine: 86 Trans AM
Transmission: 5M
Axle/Gears: ?? 2:77 I think??
Car: 89 Formula 350
Car: 89 Formula 350
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
That's sounds about right, I was hoping to get mine to peak at 5500,but with a smaller cam (228/228), not sure if that's going to happen.
. How does it pull on the street?
Get some high octane in there, see what she does with less fuel and more timing. I think you have a lot of hidden horsepower in there!
Anything else causing detonation, hot plugs, bad egr. How do the plugs read?
Car: 89 Formula 350
Thirdgen89GTA
Sep 18, 2015 09:52 PM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
