Adding a WB to Tunerpro Logging
Old Aug 25, 2011 | 10:48 PM
BB72Camaro's Avatar
I have a patched bin with my tune and the .xdf that has the flags added for my Innovate LC-1.
How do I add the output of the LC-1 to the datastream in Tunerpro?
I feel like I am real close to doing some real tuning.
Old Aug 26, 2011 | 11:02 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Adding a WB to Tunerpro Logging
If you have the bin patched then the data is there, just need to create a "Value" in TunerPro and apply the scale factor so it reads in units you can understand.
You must know from the patch, what item number in the datastream the WB data is located. Create the "Value" and then see below to configure it.
This thread has a pretty good explaination of the math needed to make the WB output match what the conversion factor should be.
https://www.thirdgen.org/forums/diy-...atalog-vs.html
Post up if you can't get it to work.
Jp
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
ULTM8Z
Oct 2, 2015 01:25 PM
