a question about a comment in one of the stickies...
Old Sep 7, 2011 | 01:24 AM
mistaben's Avatar
Car: 91 corvette
Engine: 383SR
OK, this comment is 10 years old so if no one undersands it I hold no fault here....
Originally Posted by Grim Reaper
Before you buy a bunch of eproms or a UV Eraser, go with the AT29C256 Flash Prom. If you don't know what they are, do a little searching on them and you'll realize that this is the ONLY way to go with eprom burning if you can use them. And for SD cars, you can....and the easiest of ALL cars on this board.
Second, start with the 90-91 Corvette ANHT BIN. The Corvette BIN, while VERY CLOSE to an F-body BIN, also is different. The Corvette BIN has code to work with the oil temp sensor which the F-body version does not. Also, you don't mention your transmission but you should find a version for the ANHT with a 6-speed for the Corvette if you have a manual tranny. The best place to start is, again, your own Memcal.
Changes to make BEFORE even touching the VE Tables:
1) Set your Cylinder Volume in the constant table to 784cc. This will tell the ECM what size of motor you have to calculate the proper amount of fuel.
2) Set your Injector Flow constant to the "rated flow" of the injector. If you know the "correction factor" for the particular fuel pressure you are running (I recommend around 46-48 psi), use that. But don't get too hung up as whatever you put in here is going to be changed.
3) Set your "Desired Idles Speed Vs Coolant Table". This is assuming you have set your IAC and TPS. If you have not reset your IAC or TPS, go to the "Tech Articles" on this web site and read up on how to adjust the IAC, it is VERY SIMPLE but needs to be adjusted properly before you even begin to tune your eprom.
If your IAC/TPS are adjusted properly, then go into the "Desired Idle Speed vs Coolant Temp" to make the adjustment for the idle speed you want. With your LT-4 Cam, you probably want a higher idle than the stock BIN of 600-650 RPM. Probably more like 750ish at proper operating temp.
4) Now start taking your car for a "little drive" and drive at reasonably light throttle. An interesting observation that I have made is the lower VE Table for low-mid Load (kpa) and low-mid RPM is actually very similar for ALL SD engines, if the Cylinder Constant and Injector Constant are reasonably correct.
If at part throttle (1200-1600 rpm/40-60 Kpa) are all way below BLM 128, then increase the Injector Constant to lean the engine and raise the BLM value. Conversely, if the BLMs are all way above 128, then decrease the Injector Constant to richen the engine and lower the BLM value. Do this adjustment until you are notice that half of your BLMS are above 128 and half are below 128 (best scenario) or reasonably close to somewhere between 115-140. But the closer you can get most of the readings on the 1200-1600 rpm/40-60 kpa to 128ish, the better.
5) Now you are ready to begin tuning your VE table in ernst. In fact, you may find your car is even running reasonably well and fairly close...now you have a BIN close to what someone else would probably have e-mailed you or would have bought from a custom prom writer. Follow the "P730: Part throttle tuning VE (no PE)" and begin tweaking your VE tables. This will get your fuel mixture correct and once done, you will be ready to start tweaking the spark.
The above procedure is how I start ALL my bins.
First,
I have a 7727 PCM (corvette 90-91) and am using the 7730 definition file. - what was he talking about the corvette bin has a line in it for oil temperature? will my definition file not update this?
I have tuned my VE tables through to about 3000RPM without the PE engange (well set it to 85% on my TPS) does that change anything?
Old Sep 7, 2011 | 11:26 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: a question about a comment in one of the stickies...
IIRC, The code for the oil temp input is there if you want to add the sender.
There is an A/C disable based on oil temp thresholds but I don't recall any other items relating to it.
(edit: Did a quick search through AUJP and ANHT, only thing it does is shut down the A/C clutch if temp is too high. or error codes 52, 62 if sensor out of range)
colton_carlson
Mar 8, 2019 12:21 PM
-=Z28=-
Feb 25, 2016 09:06 PM
scottmoyer
Sep 5, 2015 09:33 AM
redmaroz
Aug 16, 2015 11:40 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
