Why won't my Moates chip burner work?
Old Oct 4, 2011 | 09:40 PM
88gunmetalgta's Avatar
My car has been behaving weirdly since I burned my last chip, so I tried to burn a new one.
Using Moates Flash n Burn, and a Burn 1 programmer. Done this many many times before.
Erased chip fine,
blank check is good (even read the chip to verify after this step.)
program chip, successful
verify bin with buffer, failed (not matched)
WTF?
I read the chip again, and it has data written to it, but I haven't compared to find where the differences lie.
I'm thinking this is to blame for my car's recent weird behavior. Since when I put the chip in, it reads fine and my car will run. I'm guessing its a hardware problem with the Moates burner.
Anyone else run into a similar issue?
Old Oct 5, 2011 | 12:03 AM
Re: Why won't my Moates chip burner work?
Ok tried it again.
Burned a bin to the chip.
Read the chip, saved to a file.
read it again, and saved it to a different file.
used a bin compare utility to check for differences
Burned bin to read bin was WAAAY different.
There were differences between the two read bin files too. Not too many, but enough to screw something up I'm sure.
Really suspecting a hardware problem at this point.
Old Oct 5, 2011 | 12:29 AM
Figured it out. That's what happens when a small rock gets jammed in the zif, and prevents it from closing around the pin all the way.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
