Stall saver
Old Oct 22, 2011 | 01:04 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Stall saver
I have my tune pretty good at this point. I'm just working on a stall issue I get once in a while. If i'm going slow like under 10 mph and get out of the gas fast or break fast it will stall once in a while. I have the Idle set for 700 Rpms but it really idles around 750-800 RPMs. I'm not sure what the stall saves should be set to but right now they are at 400, 450 and 650. With stall saver disable at 350.
Old Oct 22, 2011 | 05:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Stall saver
Tuning Guide Book sticky, Chapter 5, '7730, title: Stall Saver SA and $8D
It also applies to the $6E code.
RBob.
Old Oct 22, 2011 | 06:00 PM
Car: 89 Formula 350
Re: Stall saver
Thanks RBob,
I read the sticky. So if I follow your correctly I am to change " Stall Saver Spark Enable RPM Threshold" 1,2 and 3 to a value of "0". I'm also to change " stall saver spark disable RPM thershold" value to "0" as well?? Thanks again
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
