ECM Test Cable
Old Mar 30, 2012 | 05:24 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
ECM Test Cable
Has anyone built a cable/software to replace an ecm bench for testing custom code? I'm considering doing this through the printer port and trying my hand at writing a program to monitor I/O so you can maipulate inputs via software. May be a bigger bite than I can handle right now though. Ideas?
Old Mar 30, 2012 | 06:02 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ECM Test Cable
I just use a Jim Stim for my test bench.
Old Mar 30, 2012 | 06:55 PM
bl85c's Avatar
Car: '85 maro
Re: ECM Test Cable
I want to get away from the physical ***** & such so I can run simulations of drive cycles & other stuff. Just fantasizing right now though. Can a jimstim do that?
Old Mar 30, 2012 | 09:27 PM
Re: ECM Test Cable
Sorta, there is a PC interface that, from what I remember it will run the RPM through a cycle.
http://www.jbperf.com/JimStim/index.html
Old Mar 30, 2012 | 11:24 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: ECM Test Cable
I did some stuff that worked well.
The RPM with optical setting worked well but the magnetic needed to have a zero crossing.
https://www.thirdgen.org/forums/diy-...nch-calcs.html
Old Apr 2, 2012 | 06:35 PM
bl85c's Avatar
Car: '85 maro
Re: ECM Test Cable
What are you guys doing for o2 signal? Signal generators work great for everything else but I would imagine o2 would be difficult... unelss you just feed it a constant stoich signal so it doesn't do anything. Anybody doing anything adjustable so you can upset the pid loop and test out o2 code changes?
Old Apr 2, 2012 | 07:29 PM
Re: ECM Test Cable
The JimStim has a dial for the O2, which is just a resistor changing the voltage from 0 to 1 volt, or 0 to 5 volt, depending on where the jumper is.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
