ebl surging on start up and after reving up
Car: check
Engine: check
Transmission: check
Re: ebl surging on start up and after reving up
Yes it did, Im still having a problem with it dying or surging bad after revving up which I think is being caused by more lean values in the low kpa, low rpm areas. Because I tried flattening them some after adjusting them in addittion to what you told me to add in the 55 kpa area and up. I will datalog and see.
Car: check
Engine: check
Transmission: check
Many time it is helpful to make the whole lower VE area richer to eliminate surging. Then do some VE Learns.
RBob.
