Lowering spark adv
Old Apr 17, 2012 | 05:52 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Lowering spark adv
Ok car is a 91' 350 TPI, timing is advanced to about 12 degrees on 93 octane. Runs great,but i wanna run 89. Everytime i have tried 89 i get a slight knock at about 4krpms and up. I have found retarding my distributor 1 degree to help but i like the low end power that the 12 degrees was giving me. So my question is this: what is the easiest way to remove some timing in the bin? Should i just remove it in the "Spark adv main" table at 90-100 map and 4k rpms and higher? or should i zero out the PE spark adv? any other ways?
Old Apr 17, 2012 | 08:28 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Lowering spark adv
I have a maf car but I zero out my PE timing and just adjust all my timing in my main spark table. So I guess you could lower timing in eighter area at high load over 4k. I'd pull 2* in the areas your getting knock.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
J-money
Jan 4, 2019 09:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
