prom /cal-pak?
Old Apr 23, 2012 | 11:31 PM
HorsePowerJUNKI's Avatar
Car: 86 trans am gta,and 88 corvette
Engine: TA-355ci tpi,vette 383 tpi
Transmission: 5spd manual,700r4
Axle/Gears: borgwarner 370 posi,vette is stock
prom /cal-pak?
anone know why a stock aujm chip is 64k and when i copy it my burn is 16k and not 64k.and 1 other thing will the cal-pak that comes stock with a 88vette work with a 86 trans am that has the 88 vetts engine in it? and is it the checksum that controlls that interchange between years?in other words should i disable the checksum to make it work with the 86 trans ams wireing and sensors ,ect..? thanx to anyone that might have sum advice for me
Old Apr 25, 2012 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: prom /cal-pak?
The stock AUJM is a 16 KB file, so that is correct. GM did use a larger chip then required at times. They just put the calibration into the upper half of it.
The checksum is a test that verifies that no bits have flipped in the physical PROM.
You can use the MEMCAL from the '88 Vette in the Firebird. Although it may have VATs enabled and the fan relay may be wired in reverse. IOW, fans on when should be off and vice-versa.
RBob.
Old Apr 25, 2012 | 09:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: prom /cal-pak?
do the read as a 27c128
Old Apr 25, 2012 | 06:58 PM
Re: prom /cal-pak?
thanx for the info,id like to ask you another question reguarding the same cars,computers,ect... in the trans am the check engine lite stays on all the time and i cant get the data logger to tap into the computer.im useing the correct data stream cuz its works on the vette.i tried the flashing check engine lite for codes but it wont flash eaither.now if i put the stock aujm in the trans am i can get it to flash 12 code but it wont start because of the vats.that chip runs well in the vette.so i copied it exactly with the vats disabled and it wont start it or flash any code.what am i doing wrong? any input ? thanx jon
Old Apr 25, 2012 | 07:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: prom /cal-pak?
If you don't get the SES blink at key-on, engine-off, the ECM isn't running from the PROM. Which explains the no ALDL connect and the lack of being able to flash the codes.
RBob.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
