copy then crash TunerPro 5
I just ran into this problem with Registered TunerPro 5 both RT and non-RT versions. I'm using Windows 7 64 bit. I have never had a problem until now when I was coping a spark table from one bin to another bin. I've done this numerous times without fail. This time was different. I selected the entire table, brought up the other bin and it would not paste. So I tried it again and as soon as I hit copy, the program crashed. re-started the program and sure enough as soon as I hit copy the program crashes.
I started up RT version and same thing, crashes. I shut down computer, same thing. I tried running XT mode as administrator, same thing. I can copy other things, XDF ect. but not tables.
I also have it on a XP laptop and seems to be OK on there so it is machine specific. I'm thinking a tunerpro configuration file or some DLL is hosed but don't know.
Has anyone run into this problem? And yes I will post on Mark's site. but this is usually quicker. Thanks Guys.
Re: copy then crash TunerPro 5
Update, I thought it worked on XP but I was wrong. I switched over to the laptop to finish up and as soon as I hit copy, it too crashed the program. This is really strange as I never had a problem until now. Was it an update?
Mine still works fine on mothers day?
Maybe this guy could help you? He seems like a pro at this...
http://www.ebay.com/sch/valleytek/m.html?
