Is the EBL right for me
Old May 23, 2012 | 02:09 AM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
Transmission: Th700R4
Axle/Gears: 3.27, 9 bolt Borg-Warner
Hey guys i've been thinking about getting the EBL flash ecm, but not sure if it will be the right thing for me. My set up is a 350 tbi unit with a 700r4 transmission. I have every thing to work with the 350 but the ECM. I have a few question about the EBL.
1. Would this work with my transmission.
2. Is there anything that i would need to get to make it work.
3. Would i be able to Change the tuning if i decide to add anything else to it later on.
4. Is it worth getting then a Eprom burner
5. Is there anything i should be worried about
or is there something else i should look in to and thank you for the help in advance.
Old May 23, 2012 | 04:02 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Is the EBL right for me
I would PM RBob, he is the man... I am going with the EBL P4 setup myself.
Old May 23, 2012 | 08:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, no issue.
Likely require the USB/Serial adapter cable, most laptops today don't have a serial port.
Yes, as you add/change the engine you can tune for those changes.
No need for one with an EBL Flash system.
Not that I know of, well, actually, tuning can be addictive.
The only item is that the EBL Flash ECM won't control an A.I.R. (smog pump) system. So if that is an absolute requirement, then need to stay with the stock ECM.
RBob.
Old May 23, 2012 | 02:13 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
alright cool i don't have the A.I.R system so it alright for me to get the ecm. so this should work perfectly ok with my set up. I havent tune anything yet but sounds like fun can't wait to do so
Old May 23, 2012 | 04:12 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
which are the best tuning programs to with the EBL
Old May 23, 2012 | 05:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.dynamicefi.com/EBL_ScreenShots.php
Whats up !
Old May 23, 2012 | 05:47 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Free version is the .bin editor you use.
http://www.tunerpro.net/
Old May 25, 2012 | 03:40 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
So is this the only website i could get it at
http://www.appliedgmc.com/prod.itml/icOid/1086
Old May 26, 2012 | 08:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Applied GMC does carry the EBL Flash ECMs, will want just the ECM (and possibly the USB/Serial cable), not what is shown there. That is for the Olds engines used in motor homes.
You can also purchase directly from us. Shoot me an email or PM to confirm what you are ordering and PayPal the funds.
RBob.
Old May 29, 2012 | 07:20 PM
cinder41's Avatar
Car: 1988 Firebird
Engine: 350 TBI
cool thank you I'll send you an email tomorrow morning
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
