what electronic boost controller for the ebl flash
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i'm hoping to be turbo'd by sept. an i'm wonder the best boost controllewr to run with the ebl flash . i'm asuming it has to have a wire to the computer to read boost so it can retard timing . thanks
Car: check
Engine: check
Transmission: check
Re: what electronic boost controller for the ebl flash
The EBL Flash ECM has a fuel multiplier table and a spark retard table for when in boost. The tables are by RPM & boost.
As for a boost controller, I was thinking you were looking for something to control the level of boost. There is the simple RJC controller. It fits in the boost line between the turbo and waste gate actuator.
Here is the link to the RJC unit:
http://rjcracing.com/product/boost-controller/
RBob.
Engine: l98 tpi
Axle/Gears: 2.77
ok i didn;t realize the computer would reconize boost . i forgot it has a map senser my mistake
Doobie52
Sep 11, 2015 06:19 PM
