TP "compare" Q?
Old Jul 3, 2012 | 01:13 PM
Ronny's Avatar
TP "compare" Q?
Is there a function to compare two tables based on a % difference + or - ?
If so where is it?
Old Jul 3, 2012 | 05:46 PM
LastC3's Avatar
Engine: 355 cu in CFI
Transmission: 700 R4
Axle/Gears: 355
Re: TP "compare" Q?
If so where is it?
Ron .... I'm using TP5 ... there is a compare function that is shown on the top options bar ... once the two bins are loaded, you can pull the table (VE for example) ... at the top of the table there is a 'scale' looking icon that will show you the differences ...... (( if I understand you Q correctly ))
Old Jul 3, 2012 | 06:56 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: TP "compare" Q?
Its only if there is a difference at the address location between the two files.
No way to set the amount or type of difference.
Old Jul 4, 2012 | 06:15 AM
EagleMark's Avatar
Re: TP "compare" Q?
It will show amount difference, not percent.
TP V5 Compare, Load Compare bin and it will be checked. Then when you open a paremeter like VE Fuel table and look for the scales Icon at top/Tool bar, click it and it will show the entire compared bin table, if you click the piramid looking Icon to right of it, it will show the difference in each cell of table from bin loaded to compared bin.
