VE changed
Old Jul 3, 2012 | 08:24 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
VE changed
8d Will a dirty air filter change your fueling.Mine changed
for no reason. It went rich.
Old Jul 4, 2012 | 02:30 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: VE changed
i want to state a maybe....
reason being that a restricted filter should show up as a change in MAP, which will automatically change fueling.
try a quick drive back to back with the filter on and off?
Old Jul 5, 2012 | 06:45 AM
EagleMark's Avatar
Re: VE changed
So will weather... or a mechanical issue... how bad?
Old Jul 5, 2012 | 09:41 AM
Ronny's Avatar
Re: VE changed
Maybe a diff blend of gasoline? In WI we change blends twice in the year.
Fuel pressure the same?
Old Jul 5, 2012 | 11:35 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: VE changed
Flaky coolant/MAT/IAT will throw things off very quickly.
Confirm they are all reading "normal" values too.
Old Jul 5, 2012 | 11:53 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Re: VE changed
In Calif we change blends also.
The amount af change is about 10 counts.
Fuel pressure has not changed.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
