SA differences between Manual and Auto cars?
Old Aug 6, 2012 | 11:21 AM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
I had a question about the timing strategies between auto and stick cars. Comparing AUJP (350/Auto), AXXD (305 5-speed), and AXCN (350, 6-speed), I can understand some of the differences, but one thing I don't understand is why the timing is so low in the stick bins for the low rpm high load areas. For example, in AUJP, in the 80-100Kpa and 400-600 rpm area, the timing is 20.04. In the AXXD and AXCN bins, the timing in those areas is 6 degrees and 10 degrees respectively. Why is that? I would think that the added timing in that area would help the motor stay alive if the clutch is let out without enough gas, no?
Old Aug 6, 2012 | 12:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: SA differences between Manual and Auto cars?
Lots of reasons. For auto's need to run the engine up against a heavy convertor before the vehicle starts to move.
Stick car, direct connection, also needs to be driveable. A lot of SA makes for a jumpy/jerky ride.
Emissions.
RBob.
Old Aug 6, 2012 | 11:17 PM
Thanks RBob. After studying some datalogs and trying to diagnose why my car stumbled and tried to stall in an intersection with oncoming traffic at low rpm high load conditions, I bumped up timing in those areas and noticed a big improvement in driveability. Now I just need to figure out why sometimes it almost wants to stall when I push the clutch in too quickly.
1992 Trans Am
May 10, 2023 07:19 PM
1nastygta
Oct 28, 2015 08:51 PM
kyleb24
Aug 15, 2015 08:24 AM
rsrmoore
Aug 7, 2015 08:44 PM
MENINBLK
Aug 5, 2015 11:58 PM
