O2 sensor position affect ecm?
Old Aug 8, 2012 | 02:40 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm just getting into logging/tuning etc. and have a question about the O2 sensor position and AIR injection. I've got a '91 3.1 but the question may apply to any set up. The AIR pump injects air into the exhaust manifold ahead of the O2 sensor so does this not 'corrupt' what the sensor sees? The ecm doesn't control the AIR pump so doesn't know when it's injecting air so doesn't it always have to play catch up trying to adjust for the extra air? It seems like it would be better for the air to be injected after the sensor or directly into the cat. The cat has what looks like an input tube but it's sealed off.
Old Aug 8, 2012 | 03:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: O2 sensor position affect ecm?
The AIR system only injects air upstream of the O2 sensor on a cold engine. It's stopped long before the ECM begins using the sensor and only injects into the cat, if at all.
Old Aug 9, 2012 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM does control the AIR pump in the '90-'92 3.1l f-body's. The pump air is only sent to the exhaust port when the engine is cold, under 61* F (in the AZTY calibration). So during the Summer it is always in divert mode (dump to atmo).
The ECM won't go closed loop until the engine is at 144* F. Which is well above the divert enable threshold for the AIR system.
The vacuum line to the AIR pump valve is to be sure that it goes into divert mode on decel. Otherwise it will cause backfires in the exhaust.
RBob.
db057
Apr 28, 2019 07:45 AM
skeltor
Feb 2, 2016 10:37 AM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 8, 2015 11:28 PM
willyjoejr
Sep 3, 2015 09:26 AM
