160 20 byte datastream???
Old Aug 20, 2012 | 10:53 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can someone please tell me what bytes the 160 (85' ecm) xmits?? i was able to write a program to pull the bytes but i have no idea what their for...
i did a search and read alot of threads but nothing definite...
the first byte i think is 0111 1111 or 1111 1111 (0xff) then the rest spit out..
so for example, is byte #2 tps, temp, mph, etc and so on...
i just need to know the order of what im recieving so i can convert the binary to a decimal format, thanx
Old Aug 20, 2012 | 11:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 160 20 byte datastream???
Which induction system? The 8th digit of the vehicles VIN is also helpful.
RBob.
Old Aug 20, 2012 | 11:17 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
1985 iroc-z tpi 5.0
Old Aug 20, 2012 | 12:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Code:
                        DATA STREAM A20   SPECIFICATION
       ENGINE   USAGE:
              2.8l MFI     (LB6) - (W) - 85, 86
              2.8l MFI     (LB8) - (S) - 86, 87, 88, 89
              5.0l MFI     (LB9) - (F) - 85
       DATA PIN  : READ DATA ON PIN "E" OF ALDL CONNECTOR
       BAUD RATE : 160 BAUD
       MODES     : DIAGNOSTIC ENABLE:
                     MODULATED . . . . NO
                     10K . . . . . . . YES - 25 WORDS
                     NORMAL  . . . . . YES -  8 WORDS
                     SHORTED . . . . . YES - 25 WORDS
       DEFINITION: ALL DATA STREAMS CONTAIN THE SAME INFORMATION
                   IN THE SAME FORMAT
  DATA STREAM DEFINITION
    WHERE "WORD" IS THE BYTE OF DATA STREAM AS IT IS READ FROM THE VEHICLE
    AND "BIT" IS THE BIT OF THE BYTE, WHERE 0 IS THE LEAST SIGNIFICANT BIT.
    WORD  BIT   DESCRIPTION
    1           MODE WORD 2
            0   ROAD SPEED PULSE OCCURRED                1 = PULSE OCCURRED
            1   ESC FAILURE
            2   REFERENCE PULSE OCCURRED                 1 = PULSE OCCURRED
            3   DIAGNOSTIC SWITCH IN FACTORY TEST        1 = 3.9K MODE
            4   DIAGNOSTIC SWITCH IN DIAGNOSTIC POSITION 1 = SHORTED MODE
            5   DIAGNOSTIC SWITCH IN ALDL POSITION       1 = 10K MODE
            6   HIGH BATTERY VOLTAGE                     1 = HIGH VOLTAGE
            7   AIR METER PULSE OCCURRED
    2           FIRST PROM ID WORD
    3           SECOND PROM ID WORD
    4           IAC PRESENT MOTOR POSITION
    5           COOLANT TEMPERATURE   A/D COUNTS
    6           FILTERED MPH VARIABLE - VEHICLE SPEED
    7           EGR DUTY CYCLE
    8           ENGINE SPEED
    9           THROTTLE POSITION  SENSOR
   10           BASE PULSE CLOSED LOOP CORRECTION
   11           OXYGEN SENSOR
   12           MALFUNCTION FLAG WORD 1
            0   C24 VEHICLE SPEED SENSOR
            1   C23 MANIFOLD AIR  TEMPERATURE LOW
            2   C22 THROTTLE POSITION SENSOR LOW
            3   C21 THROTTLE POSITION SENSOR HIGH
            4   C15 COOLANT SENSOR LOW TEMPERATURE
            5   C14 COOLANT SENSOR HIGH TEMPERATURE
            6   C13 OXYGEN SENSOR OPEN
            7   C12 NO REFERENCE PULSES (ENG. NOT RUNNING)
   13           MALFUNCTION FLAG WORD 2
            0   C42 EST MONITOR ERROR
            1   C41 CYLINDER SELECT ERROR
            2       NOT USED
            3   C34 MAF SENSOR LOW
            4   C33 MAF SENSOR HIGH
            5   C32 EXHAUST GAS RECIRCULATION FAILURE
            6       NOT USED
            7   C25 MANIFOLD AIR  TEMPERATURE HIGH
   14           MALFUNCTION FLAG WORD 3
            0   C55 ADU ERROR
            1   C54 FUEL PUMP VOLTAGE
            2   C53 HIGH BATTERY VOLTAGE
            3   C52 CAL PACK MISSING
            4   C51 PROM ERROR
            5   C45 OXYGEN SENSOR RICH
            6   C44 OXYGEN SENSOR LEAN
            7   C43 ELECTRONIC SPARK CONTROL FAILURE
   15           AIR-FUEL (A/F) MODE WORD
            0   FOURTH TPS FORCED O/D DISABLE
            1   LEARN CONTROL ENABLE FLAG   1 = ENABLE
            2   LOW BATTERY VOLTAGE         1 = LOW BATTERY
            3   PROP STEP TAKEN FLAG        1 = RICH
            4   VEHICLE SPEED SENSOR FAILURE
            5   EECC SLOW O2 RICH/LEAN FLAG
            6   RICH LEAN FLAG              1 = RICH          0 = LEAN
            7   CLOSED LOOP FLAG            1 = CLOSED LOOP   0 = OPEN
   16           MANIFOLD AIR TEMPERATURE
   17           MCU INPUT STATUS WORD
            0   PARK/NEUTRAL                1 = PARK          0 = DRIVE
            1   FAN REQUEST                 1 = NO/OFF        0 = YES/ON
            2   TCC LOCKED OR OVER DRIVE ENABLED 1 = ENABLE
            3   EXCESSIVE POWER STEERING PRESSURE
            4   100 MSEC OLD 4TH GEAR (SET/CLEARED IN TCC)
            5   NOT IN 3RD GEAR             1 = NOT IN 3RD
            6   4TH GEAR SWITCH CLOSED      1 = NOT IN 4TH    0 = IN 4TH GEAR
            7   A/C REQUESTED               1 = NO            0 = A/C REQUESTED
   18           LOAD VARIABLE
   19           BLOCK LEARN MULTIPLIER
   20           ALDL RICH LEAN CHANGE COUNTER / TOTAL CROSSOVER COUNTS
   21           UNLIMITED SPARK ADVANCE  (not used)
   22           MASS AIR FLOW RATE BYTE #1  (MAF)
   23           MASS AIR FLOW RATE BYTE #2  (MAF)
   24           BASE PULSE WIDTH BYTE #1
   25           BASE PULSE WIDTH BYTE #2
        CONVERSION FOR A/D COUNTS TO ENGINEERING UNITS
                N = A/D COUNTS
               EU = ENGINEERING UNITS
                EU = N*A + B
                EU =
                EU = N
                EU = TABLE LOOKUP
                                                         ENGINEERING
    WORD   DESCRIPTION                     CONVERSION      UNIT
    1      MODE WORD 2                     NONE
    2      FIRST PROM ID WORD              NONE
    3      SECOND PROM ID WORD             NONE
    4      IAC                             NONE
    5      COOLANT TEMPERATURE             SEE TABLES       DEGREES C
    6      VEHICLE SPEED                   NONE
    7      EGR DUTY CYCLE                  EU = N/2.56     % DUTY CYCLE
    8      RPM                             EU = N*25        RPM
    9      THROTTLE POSITION               EU = N*.0196     VOLTS
   10      BASE PULSE CLOSED LOOP CORRECTION    NONE
   11      OXYGEN SENSOR                   EU = N*4.44      MILLIVOLTS
   12      MALF FLAG WORD 1                NONE
   13      MALF FLAG WORD 2                NONE
   14      MALF FLAG WORD 3                NONE
   15      FUEL-AIR MODE WORD              NONE
   16      MANIFOLD AIR TEMPERATURE        TABLE LOOKUP
   17      MCU INPUT STATUS WORD           NONE
   18      LOAD VARIABLE
   19      BLOCK LEARN MULTIPLIER          NONE
   20      ALDL RICH LEAN CHANGE COUNTER   SEE **
   21      UNLIMITED SPARK ADVANCE         Not used !
   25      BASE PULSE WIDTH BYTE #2        EU =(BYTE1*256+BYTE2)*.0153 *** MS
 ** : THIS IS A ROLLOVER COUNTER (0 - 255), TAKE CURRENT DATA STREAM READING
      SUBTRACT LAST DATA STREAM READING = CROSSCOUNTS.  IF CURRENT READING
      MINUS LAST READING IS < 0, THEN TAKE CURRENT READING + 255 - LAST
 ***: THIS READING SHOULD BE THE DIFFERENCE BETWEEN THE LAST TWO READINGS.
      TAKE CURRENT DATA STREAM READING SUBTRACT LAST DATA STREAM READING FOR
      ACTUAL MS VALUE.  FOR FIRST DATA STREAM, THAT READING IS THE MS VALUE.
RBob.
Old Aug 20, 2012 | 12:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here is the conversion chart for the IAT/MAT. Not sure if it will work with the CTS. If the CTS ADC changes abruptly at a particular temperature then it uses dual pull ups. It will be difficult to know the actual coolant temperature.
Code:
        AIR TEMPERATURE SENSOR TABLE
        DEGREES C               A/D COUNTS
        -40                        0
        -30                        4
        -25                        5
        -20                        8
        -15                       10
        -10                       14
        - 5                       18
          0                       24
          5                       30
         10                       37
         15                       46
         20                       56
         25                       66
         30                       78
         35                       90
         40                       103
         45                       116
         50                       129
         55                       141
         60                       153
         65                       163
         70                       174
         75                       183
         80                       191
         85                       199
         90                       295
         95                       211
        100                       216
        105                       221
        110                       225
        115                       229
        120                       232
        125                       234
        130                       237
        135                       239
        140                       241
        145                       241
        150                       243
        200                       255
RBob.
Old Aug 20, 2012 | 12:47 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
sweeeet!!!!!!!!!
do have it for the 8192??? its for my 2nd iroc-z, 1988 tpi 350
Old Aug 20, 2012 | 03:26 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
anyone??
Old Aug 20, 2012 | 08:04 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
what mode do i use when the car is running for live data?
10k, 3.9k or jumpered??
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Pinguiclia
Oct 12, 2015 04:47 PM
Nervous2
Oct 8, 2015 10:53 PM
