Quick TunerPro RT v5 question
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
In TunerPro, when viewing MAF table graphs, there are 3 different lines on the graph. The black one shows the data for the bin you are viewing and the gray one is for the "compare" bin data. What does the green line represent? It appears to be close the the black line (current bin data) but deviates here and there. How can it be used for tuning?
Re: Quick TunerPro RT v5 question
On mine, V5, I don't have a grey line. It kinda depends how you have the buttons pushed when you open the graph. With none or just the show compare pushed, I get a red and a black. Black is your bin and red is compare. But if I have both pushed then I get a black difference (normally at bottom) It also depends on if you have the show/hide compare button pushed on the graph itself. I have noticed on some bins that the compare is in green. Don't know why.
Car: 89 IROC
Engine: 6.8 HSR N2O
I see what you mean about the compare value vs the compare differance. And possibly the color of the line is based on preferances, but there are 3 distinct lines on my graph. On mine the current bin and this mystery line are very close, but not exactly the same. I am speculating that it may be a "smoothed", filtered or average value. ???
buckeyecelt
Sep 24, 2015 05:50 AM
