7165 Prom in 7730???
Old Sep 17, 2012 | 01:52 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
Ok so its been a long time. Finally getting back into everything and after a lot of research I have what is most likely a stupid question.
Yesterday i picked up another TPI setup (ASM and edelbrock parts, small cam, blah blah blah), it came with a 7165 that has the smog with EGR removed, it is a MAF setup. Im using a 7730 on my current TPI same as above except it is a SD set up and I will be sticking to SD with the new motor.
Can i swap proms since my 7730 has all emissions still remaining (dont need or want them currently)? Just looking for a quick solution until I get everything necessary to tune myself.
Old Sep 17, 2012 | 02:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 7165 Prom in 7730???
$32, $32B or $6E in a 730 will put the ecm in LHM.
Old Sep 17, 2012 | 02:58 PM
Car: 82 El Camino
Engine: built 355
thank you. i assumed it wouldn't work.
Posted from Thirdgen.org App for Android
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
