$8D with 3-spd auto
Old Oct 1, 2012 | 11:38 AM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
$8D with 3-spd auto
since ive only used 8D exclusively with the T5, i have almost no idea how the logics work with the auto trans. what would i need to change to use 8D with a 3spd auto?
Old Oct 1, 2012 | 07:33 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: $8D with 3-spd auto
There's really no control other than the converter lockup.
The IAC settings are different to make running smoother with the added loads from the converter.
If its not a lockup trans, just run the stock auto trans IAC settings and get the VSS to work and it should be fine.
Jp
Old Oct 1, 2012 | 09:19 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Jp
well today i tried running the car(86 fiero se v6) with it but was unsuccessful. TP connects but everything blinks like a christmas tree. went through and set everything up for 6 cyl, injectors, cyl vol, etc. wouldnt fire. found out that map signal was on wrong pin, the factory harness has 2 wires for map. switched it over, and for some reason the map voltage was at 2.5v(key on engine off), maybe since im 2500ft above sea level. not sure if its a bad ground but ran out of time, had to go to work. ill try to get a datalog to show whats going on, the $88 adx connects but not the SAUJP 8D, even though everything is wired exactly the same. id like to use SAUJP because i know it fairly well now so any glitches can be cleaned up faster, and it has WB capes. thanks!
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
