Tunerpro question...how to view Maf readouts as Volts not grams
Old Oct 22, 2012 | 04:57 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I could not figure out how to switch the maf readouts in dataloging from grams to volts. Anyone able to help on this one. I did do a search to see if i could find this too. I just want to be able to see what voltage the maf is at so that i can richen it up or lean it out.
Old Oct 22, 2012 | 05:33 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Tunerpro question...how to view Maf readouts as Volts not grams
Read this.
https://www.thirdgen.org/forums/diy-...scellanea.html
Old Oct 22, 2012 | 06:42 PM
subroc's Avatar
Engine: 355 TPI
Read through that now. I think i need to read through it again. Head spinning.
Old Oct 24, 2012 | 06:33 PM
caboboy's Avatar
Car: '87 Corvette Convertible
Engine: 421 CID, Superram, LPE219, AFR 195s
Transmission: Built A4
Axle/Gears: D44 w/ 3.07s
This thread may help you: https://www.thirdgen.org/forums/diy-...f-voltage.html
Mark_ZZ3
May 24, 2018 01:02 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
