Tunerpro does first OBD-II message frames!
Old Feb 19, 2013 | 07:22 PM
  #51
gp90gta's Avatar
Car: 1990 GTA
Re: Tunerpro does first OBD-II message frames!
Does the MAF update the VE tables? I did something like this last year on my car, someone needed my help programing an aftermarket MAF called the DBX97 from Abaco, I put on my car to play with it, hooked it up to WB input of my 7730, logged it in a histogram then copy pasted the conversion to my VE tables, worked out good.
Old Feb 19, 2013 | 10:00 PM
  #52
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ok nevermind!
I had a brain fart about how it did the calculations. The conversion from grams to liters is interchangeable and differs only by the specific gas constant for dry air. Theyre both the same technically, but at the time I did the vortec hac I chose to use liters for direct conversion to VE in tunerpro as the conversion is as simple as just dividing by the cylinder volume. GM represents it as grams, so the two conversions look different, but in fact are equivalent. Scaling my conversion factor by R directly gives GMs conversion for their funky grams*K/kPa.
Old Feb 19, 2013 | 10:42 PM
  #53
Car: 88 Camaro SC
Engine: SFI'd 350
It works provided the MAF is calibrated. The conversion to get VE from the mass airflow readings is:
([MAF grams/sec]*287.05*([IAT deg C] + 273)*120)/([MAP kPa]*1000*[RPM]*[engine displacement in L])
Old Feb 19, 2013 | 10:51 PM
  #54
Car: 88 Camaro SC
Engine: SFI'd 350
Originally Posted by EagleMark
That was exactly what I looked like the first time I saw it!
1.1xxx
When set to VE% it looks normal. 50
When set to grams/cylinder it looks like dimented24x7 history table above. .0xxx
When set to grams/second it is 123.xxx and looks to be same as TunerCat...
To be clear, mine are not in %, but as a scalar giving the ratio of volume the air moves to that of the engines displacement. For example, in my 4800 RPM/100 kPa cell, .959 is 95.9% volumetric efficiency. My XDFs use the same notation. More confusing semantics.
Although on second thought I should probably check the LS1 XDFs to make sure they are correct. I do recall taking into account the differences to make sure my notation gaves the actual correct VE values using GMs funky composite value, but its worth checking. I will also probably change them to %. just so theres no more confusion
Edit: The LS1 XDFs are correct as far as the conversion. I will re-release the fueling one with the corrected VE % tables.
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
3.8TransAM
Sep 27, 2015 08:37 PM
6998poncho
Sep 25, 2015 02:56 PM
