AUJP $8d-BLM Update Rate Conversion Formula
Old Jan 24, 2013 | 06:59 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Question: Is the conversion formula for BLM Update Rate at 0x851B in AUJP XDF files correct? Have been looking at this because a recent review of the AUJP code revealed a conversion formula in the comments different than that in the AUJP XDF files. Apparently someone believed the commented formula was correct. Here are the 2 formulas, where:
  • ‘X’ = Decimal # of executions ([Exec] = passes through the code) to produce the desired update rate in Seconds
  • Units of measure are included for clarity and to ensure cancellations equal “Seconds”
In AUJP XDF: Seconds = ((0.05 Seconds / 1 Exec) * X Execs) + 1 Second
In AUJP Comments one line below label LCCFF: X = (Seconds * 20) + 1
Solving for Seconds yields:
Seconds = (X – 1) / 20 = (X – 1) Execs * (.0.05 Sec / 1 Exec)
Clearly different formulas. So which one is correct? The XDF formula uses “1 Second” in the calculation and the comments formula uses “1 Execution”. From an assembly language perspective, the comments formula appears correct because it uses 1 execution apparently for overhead of the Assembly language instruction. On the other hand, the XDF formula uses 1 second added to the calculated value. Is this purposeful by GM to slow down the BLM update rate from that resulting from the true number of executions?
Why is this important? Because some using AUJP have reduced “BLM Update Rate” from 2.40 seconds (X=28, $1C) to something lower, like 2.0 seconds (X=20, $14) and this would be counter to what GM was trying to accomplish. But if that was not GM’s intent, then the AUJP comment formula with X=28, $1C yields 1.35 seconds (versus 2.40 seconds using the XDF formula). And using X=20, $14 yields 0.95 seconds which might be too quick for accurate BLM updates.
My vote is for the AUJP comment formula.
If you feel differently, let’s discuss it; or if you know which is correct, would appreciate your reasoning.
Thanks!
Old Jan 24, 2013 | 11:32 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Re: AUJP $8d-BLM Update Rate Conversion Formula
i could try it to see if one would be drastically different from the other
Old Jan 26, 2013 | 09:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The conversion appears to be this:
Delay in milli-sec = 50.000000 * X + 50.000000
So a value of 28 would be 1.45 seconds, along with the update amount being 2
RBob.
Old Jan 26, 2013 | 07:55 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Agree that before any adjustments, in seconds, it's X/20 or
.05 secs * X executions
1 execution
But how does one know to add the 50 msec (.05 sec)? Does this have to do with assembly instruction execution cycles, branches, etc, and if so how does one know to make this adjustment? Please elaborate if you can so I can understand the details.
Bottom line, I agree with your anaysis and that confirms that the formula is incorrect in the downloaded AUJP xdf files, and that reducing it is likely not a good idea for accurate reporting of BLMs.
Old Feb 19, 2013 | 12:27 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Code:
                 ldab    *L00ED             ; BLM UPDATE TIMER
                 incb                       ; INCREMENT TMR VALUE
                 bne      LCCFF             ; BR IF NON ZERO
                                            ; ... else [= zero with Carry set]
                 decb                       ; DECREMENT TMR VALUE
LCCFF:           stab    *L00ED             ; Save BLM UPDATE TIMER
                 cmpb     L851B             ; BLM update rate [$1C, 28d=1.40 sec]
                 bcs      LCD5D             ; BR IF Carry Set, LESS THAN 1.40 sec
                           |                ; Do BLM Update
LCD5D:                                      ; Not time for BLM to update
I've been struggling to understand this. The Counter is initially zero. Looking at the AUJP code, exactly 28 passes will be made at 50 msec each (=1.40 msec). And on the 28th pass, the Carry bit will no longer be set because the counter will = $1C 28d, so the code will NOT branch to LCD5D. That would seem to say that the formua should be 50msec * X (for 28 iterations), and not (50msec * X) + 50msec (which would be 29 iterations).
Am I looking at this incorrectly?
Old Feb 19, 2013 | 04:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sometimes it is best to put the RAM variables into the data log and run it on the bench. Higher speed data logging also helps. There have been times that I've beat my head on the wall trying to figure out timing loops and such as this one.
But when you can see the data, it becomes much more clear. And much less of a headache.
And honestly, does it really matter if the equation is one or the other? We are talking about a 50 milli-second difference over a 1.5 to 2.0 second interval.
RBob.
Old Feb 20, 2013 | 04:25 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
RBob.
Certainly understand that 50 ms is a rounding error in the scheme of 1-2 seconds. Am just trying to learn how a formula conversion might be initially derived from how a variable is used in the code.
LittleFranks
Oct 7, 2015 11:26 PM
aharvel50
Sep 21, 2015 07:31 PM
90formulaVortec
Sep 8, 2015 12:42 AM
90formulaVortec
Sep 7, 2015 06:54 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
