EBL 5.4Lcal(3001.bin) question
Old Jan 25, 2013 | 12:49 PM
Ronny's Avatar
why is the Inj correction mult TBI only value for 14.4V at zero. Same value in L03.bin?
should it not be a positive or neg number not zero? Reason being the inj size and FP diff between the two bins.
Old Jan 26, 2013 | 09:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL 5.4Lcal(3001.bin) question
Doesn't require any correction at that voltage. You could say that it is the base voltage, with negative correction above that, and positive correction below that.
Also note that the change is in percent, so a value of 0 is a change of 0%.
RBob.
Old Jan 28, 2013 | 10:01 AM
Ronny's Avatar
[QUOTE=RBob;5473717]Doesn't require any correction at that voltage. You could say that it is the base voltage, with negative correction above that, and positive correction below that.
So at 14.4 volts it is getting its correction from "offset" soley?
Old Jan 28, 2013 | 10:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
[QUOTE=Ronny;5475335]
Yes.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
soarestransam
Aug 24, 2015 08:15 AM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
