EBL question
EBL question
Thinking about switching up intakes. Currently have a HSR with a EBL flash with the port mod. If i decide to go with a FAST tbi unit what problems could be encountered since the EBL has the port mod.....
Car: check
Engine: check
Transmission: check
Re: EBL question
The injectors won't be firing at each spark plug firing. So there may be some cylinder to cylinder fuel distribution issues. With a TBI injector firing scheme, each of the two injectors fires on a plug firing, alternating between injectors.
With the Port Mod the injectors fire once every engine revolution. Which on an 8-cyl engine is once every four spark plug firings. When the PW gets small it will revert to single fire mode. Which is a doubling of the PW and firing once every two engine revolutions.
RBob.
RBob.
