ECU swap?
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
ECU swap?
Can an ecu from a Tbi 92 305 RS camaro work in a 93 GMC 350 suburban also w/Tbi, I do know that the camaro had a 700r4 while the GMC is 4l60e equipped?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECU swap?
Not a plug and play bye any mean get a 16168625 or a 427 for the 93.
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Engine: Lb9
Transmission: M20
Re: ECU swap?
If you wanted to repin and ad a iat and reprogram the 746 yes it will work but its a wated effort.
eightsixseven
Dec 16, 2024 01:50 PM
