$8D Open Loop
Old Jul 3, 2013 | 09:41 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
$8D Open Loop
Is there a scalar to enable/disable closed loop at a particular temp. The only thing that I can find are two scalars to enable closed loop at a particular rpm and force open loop below a particular rpm. Would these be used instead? Thanks
Old Jul 3, 2013 | 10:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: $8D Open Loop
Minimun temp for cL 0x0489
Old Jul 3, 2013 | 10:13 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: $8D Open Loop
Thanks.
Old Jul 3, 2013 | 10:14 PM
Engine: Lb9
Transmission: M20
Re: $8D Open Loop
sounds like you were asking how to disable it , If that the case its at 147F max this setting.
Old Jul 4, 2013 | 08:01 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: $8D Open Loop
I do plan on disabling closed loop. If it works in the same manner as 6E then yes I will max it out.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
