88 TBI ECU in a 90 TBI car
Old Sep 25, 2013 | 12:33 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Ok so I just finished swapping my 90 305 TBI Formula Auto over to a T-5 manual transmission. When I bought the transmission an ECU out of an 88' T-5 car was included.
The car runs and seems to drive fine with the automatic ECU with the neutral safety switch in the Park position. Is there any reason that I need to swap the ECUs? Does anyone have pinouts for these different ECUs?
Old Sep 25, 2013 | 02:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 TBI ECU in a 90 TBI car
The 88 1228063 is a one year only ecm. The 1228746 89-92 tbi f-body is a plug and play once the vats is removed from the prom programing. Unless the car is bucking on decal or unless you want a more common ecm no reason to do the swap.
Old Sep 25, 2013 | 02:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try the '8063 ('88) ECM and see how it is. You may find that it has more get up and go.
Note that the P/N input to the ECM should be open (drive position).
RBob.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MENINBLK
Aug 5, 2015 11:58 PM
