88TPI autoprom running screenshot of data
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Ok I finally got around to hooking up my 88 auto lb9 tpi 2.73. Took me a while to get it working and I found my way around the tool. Since this will be a resto project I took snapshot of my datalog to show you guys and see if way out of wack? I know it runs rich and sat for a while but maybe you can help point me right direction for other tools to look in tunerpro.
My Questions:
I was in Data autoprom mode to save this, simple enough. But with just aldl plugged in no g1 adapter what tool and mode do I use to grab the bin off my stock ecm ?
2: I can see the data view and dash board but is there a live view where I can see the data change across a 2d table? I assume that is where you can see where the BLM are and maybe tweak the FE tables?
My Questions:
Re: 88TPI autoprom running screenshot of data
One more thing I did not see the VAT/codes or hard to tell if they are tripped or not in the flags/scaler section? Maybe because I did not have a bin file downloaded it was just streaming obd1 data and thats it?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Let the engine warm up more, you're o2 isn't active yet in your screen shot. more than likely your $32b doesn't have vats enabled.
Thanks. It's so rich in the garage was brutal lol
But did the tps voltage look off? This was all at idle it seems to hold 700 but drops low. Little gas until it goes closed loop and it idle we'll just a little rich
What about pulling my stock bin from the car what option do I use?
Engine: Lb9
Transmission: M20
You can read your memcal on the apu1 burner/reader as a 27c128 on a header or hdr1, I'm not sure what adx your using I haven't used $32B but airflow GPS at idle will be around 9, tps voltage on the blue wire koeo will be .54v. If that is correct there maybe a issue with the 32b hack data stream.
Ok can I read the memcal thru the aldl cable and da mode or do I need to pull from the ecu?
U mean the tps should be .54v at the sensor wire, don't trust the .37 reading in the log?
Airflow should be 9 at idle? Dam mine is 2999
Engine: Lb9
Transmission: M20
I'm not sure if the data is accurate for example injector pw and airflow GPS .
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: 2.77
Hdr1 is what you'll need as shown in the above pic. I just bought my Autoprom last week & figured that out. I ordered it yesterday.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
