MAF 33/34 codes
Old Oct 10, 2013 | 09:21 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
MAF 33/34 codes
I have this thread on the electronics section but I thought I'd put it here as well since I do some DYI Prom stuff with a Moates emulater/TunerPro. Can you guys offer any insight?
Upon a light cruise or letting off the gas pedal, all of a sudden I get codes 33 or 34 and the car starts sputtering and bucking then it goes away. On the scanner it appears that when this failure happens the MAF values lock in place, sometimes high sometimes low. I am trying to check the wiring from the computer to the MAF sensor, changing the MAF (swapped out with an old one, no change / have a new one on the way). Already checked the relay's. Can you guys make any other suggestions? Thanks!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
