TunerPro RT 5.00.8040.00 build
Old Oct 17, 2013 | 10:48 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Currently, trying to use TunerPro RT 5.00.8040.00 build to monitor my 1989 camaro with definitions from TunePro website 1227165_6E, stock compute. Since I am using V5 followed the instructions to convert definitions to ADX file. It seems to work but it consistently has a glitch were on a reoccurring frequency the data jumps off the map, so to speak. I have been Google searching this issue but have not been able to find an explanation of this issue and how to fix it. Can anyone help me?
350 TPI
700R ....soon T56
built 3.08 10 bolt
Edelbrock intake manifold with ARP bolts
SLP Runners
Hedman Headers and Y-Pipe
Flowmaster cat back
Descreened MAF
Custom chip
MSD 6A digital, wires, coil
Bosch plugs
24 lb injectors
255 Walbro fuel pump and wiring kit
K&N filters
Founders control arms, panhard arm, relocation bracket, strut mounts
UMI strut brace
SLP Torque Arm
Sophn tie rod Adjusters
Energy Suspension Front Control Arm Bushing
Energy Suspension Motor Mounts
16" Iroc Wheels
Old Oct 18, 2013 | 08:38 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: TunerPro RT 5.00.8040.00 build
Not to say this is it, but I had a glitch in a banking program that would cause a loss of data. it turned out to be the screen saver program. When it changed background screens (every five minutes) it would disrupt the banking program.
I'm not saying this is the problem or this is what will fix it, just reporting some weird stuff I've had happen to me. Just don't overlook what may seem completely unrelated.
Dave
Old Oct 18, 2013 | 12:28 PM
rwstegne's Avatar
Engine: 5.7L
Thanks, I will change my screensaver and background settings, plus I just downloaded the latest version. Hope these fix it the glitch.
Old Oct 19, 2013 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
+2 on the screen saver, the Windows screen savers take a lot of CPU. Best to just disable it, not needed anyway. I've never enabled it on the laptop I use for data logging and tuning.
RBob.
Old Oct 19, 2013 | 11:09 AM
rwstegne's Avatar
Engine: 5.7L
Thanks guys. Changing the screensaver, background and power management settings fixed turnerpro from losing connection while driving. I original thought it was a usb issue but I was wrong.
Just got back from a drive, the latest version of tunerpro and the change windows settings seemed to work better. Need to look at the recording so I will update this post later when I have some time.
Trying to figure out if my shorty hedman headers and a single wire O2 sensor will work or if I need to upgrade to a hotwire setup.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Jorlain
Oct 8, 2015 01:57 AM
ULTM8Z
Oct 2, 2015 01:25 PM
