27FS512 chip problems
Old Oct 21, 2013 | 09:46 PM
Knuckl3s's Avatar
Car: 91 camaro rs
Engine: 350 tbi. Rv cam. Edelbrock headers
Transmission: stage 3 700raptor 2400 stall
Axle/Gears: 3.42 posi+disc brakes
Hey guys I may be in the wrong area but I need some help. I jus got my ecm back from moates. I had them install a 28 pin adapter. I put my chip that I programmed using a caprice bin then modifying it the car idles high But other than that I can't tell what's going on Cus my ddata logger on tuner pro won't connect. It connected fine to my stock ecm with the stock chip in it. If anyone can shed some light on my problem it would be very helpful. And also I'm a lil confused on torque converter lockup settings. Also I am using burn2 with flash and burn thanks
Old Oct 22, 2013 | 08:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 27FS512 chip problems
Be sure to burn the top of the chip. The chip is much larger then the stock one.
TCC, see the tuning guide book sticky: TCC Logic thread.
RoOb.
Old Oct 22, 2013 | 01:48 PM
Knuckl3s's Avatar
Car: 91 camaro rs
I used the 4k bin offset method from moates. So I think that is right. Could the mask Id make that not communicate I think that's the one that should be 61 right?
Street Lethal
Apr 30, 2019 12:14 PM
inferno15
Aug 29, 2015 01:48 AM
ambainb
Aug 29, 2015 12:43 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
