7730 ecm....
Old Dec 2, 2013 | 06:47 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
7730 ecm....
So, i just purchased a used "as is" ecm off of ebay.
It is a 730 and i opened it up after i heard a sound when i moved it. Ends up the esc was broken off the memcal and just laying in the ecm case.. everything else looks fine...
Can we buy replacement esc modules that pop in? Or do i have to purchase a whole memcal? I'm planning on buying a g1 adapter to start tuning my car so i dont care about the prom that is in it currently..
I only payed $35 shipped to me..
Old Dec 2, 2013 | 06:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 7730 ecm....
Looks like it was pried out. You can reinstall the header pins and easily solder it back in.
Old Dec 2, 2013 | 07:00 PM
JacobIroc's Avatar
Re: 7730 ecm....
I thought the same thing.. so i can just get new pins and resolder them at the chip then press it back on the memcal? The other pins are in 2-3 pieces.
Old Dec 2, 2013 | 07:16 PM
Engine: Lb9
Transmission: M20
Re: 7730 ecm....
Sorry I didn't see the completely broken ones between the netress and I/o. You will be better off using another memcal and solder on the netress and I/o and solder in a d2 inplace of the prom.
Old Dec 2, 2013 | 07:34 PM
JacobIroc's Avatar
Re: 7730 ecm....
Ok i will look for a memcal. Thank you
Old Dec 2, 2013 | 07:39 PM
JacobIroc's Avatar
Re: 7730 ecm....
Is it possible to use the maf esc with the 730 ecm?
Edit: seller reimbursed me half $12.50, for the damage. So i think i still did ok considering. I have a whole 22.50 into a 730 ecm and probably $50 into a reman memcal with a prom.
BWilcox
Sep 20, 2015 12:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
LBSZ28BLOWN
Jun 12, 2002 03:29 PM
HighHopes85
Jun 8, 2001 05:21 PM
